simply not true
https://www.cnn.com/2021/02/18/politics/texas-power-outages-political-fallout/index.html
But solar and wind energy make up just a fraction of Texas' energy supply, particularly in the winter.
"We have a fossil fuel-dominated grid," said Michael Webber, an energy resources professor at the University of Texas at Austin. He said it is "disingenuous to blame the grid's struggles" on renewable energy, which makes up a relatively small share of the state's energy supply.
"It's really a bigger failure of the natural gas system," Webber said. "That's the part that really struggled to keep up."
While they aren't directly to blame, note the emphasis in that first line: "particularly in the winter", this is because solar output is lower in the winter as are wind patterns.
Also, describing wind (solar truly is a very small segment) of the Texas electricity supply as "just a fraction" is misleading. In terms of installed capacity, Texas has north of 28,000MW of wind, making it the 2nd largest source in the state. And before I get called a liar on that again (happened in another thread), here's a PDF from ERCOT that shows installed capacity for various sources:
http://www.ercot.com/content/wcm/lists/219736/ERCOT_Fact_Sheet_2.12.21.pdf
While that sheet references exclusively installed capacity (~25,000MW), there is significant wind that's been grid connected but not yet recognized as installed capacity. It IS however factored into the charts ERCOT produces for supply, capacity factor...etc. This bumps overall capacity to north of 28,000MW, or roughly 28%. That's reflected in this chart:
www.ercot.com/content/wcm/lists/197386/Capacity_Changes_by_Fuel_Type_Charts_September_2020.xlsx
However, the blame still falls on the inability for gas gen to do its job to step-in for absent wind capacity as well as primary capacity, but I don't think it fair to ignore that wind's contribution to the event wasn't significant simply because it wasn't expected to show up at anywhere near nameplate in the first place.
This report covers why that is the case:
www.ercot.com/content/wcm/lists/197378/SARA-FinalWinter2020-2021.xlsx
ERCOT only plans on, during the winter demand peak, there being 963MW of wind and solar capacity.
If you go to the 2nd tab, the top table shows average CF for the three different wind areas, which gives a total average anticipated capacity of 6,142MW
This report explains why:
http://www.ercot.com/news/releases/show/216844
ERCOT said:
The peak demand forecasts for winter 2020-21 and spring 2021 were developed using Moody’s economic data obtained in April 2020. The winter SARA includes a 57,699 MW winter peak demand forecast, which is based on normal weather conditions during peak periods, from 2004 through 2018. ERCOT’s all-time winter peak demand record was set on Jan. 17, 2018, when demand reached 65,915 MW between 7 and 8 a.m.
Nearly 83,000 MW of resource capacity is expected to be available for the winter peak, including 963 MW of planned winter-rated resource capacity consisting of wind and utility-scale solar projects.
It is typical for cold snaps and heat waves to be accompanied by periods of low wind. This is perfectly normal, which is why planned available wind capacity is so low. But it does highlight an issue with expecting meaningful contribution from wind during high demand periods. The bottom line is that Utilities don't. They plan on using other capacity.
That presents a serious issue if the plan is deep decarbonization with a further reliance on electricity as we push for electrification.
