one (more) zaino application question
JHZR2
Staff member
New Jersey
OK, so per my other threads, Im putting on Z5, and will top it with Z2 and Zcs. The Z5 pro is finished, I got two coats on with ZFX. Im also going to bed, so wen I start again (tomorrow AM likely), the Z5 will be cured.
So my questions are:
Since the Z5 wil have been cured, shall I apply Z2 pro or ZFX enabled Z2 pro for best results?
Since I need to use the car and it will be out for a few days before Im able to run the Zcs on it, what will I need to do in order to apply the Zcs at a later time? I assume wash with Z7, perhaps apply another coat of Z2 to provide a cured top coat of protection, then apply Zcs?
Should I look to use Zcs as a topping coat aftr washes to keep my Z5/Z2 setup like new, or should I use Z8 or perhaps nothing, and just reapply after some time?
Thanks!
I'd use Z8 as a gloss booster and CS for times when you want more protection but don't have the time for a full scale Z2pro application.
You don't have to use the CS all the time. I recently redid my car, started with a wash, clayed, washed, AIO, then 3 coats of Z5, one each day since I wasn't driving the car. Before each coat of Z5 each day, I wiped down the car with Z6 to clean it off. Then did a coat of Z2, wiped it off, then applied the CS in the same day. I didn't use ZFX since I was doing 1 coat each day. Now all I have to do is wash it with Z7 and finish with Z6. That will last a long time. If I want to add a coat of polish, I'll choose if the car needs Z5 or Z2, and do 1 coat after the wash. It goes on and comes off so easily it's not a big deal to apply a coat after a wash.
