Looks good. It should also work on bicycle wheel bearings and bottom brackets, but #1 for gear clusters.
Other applications for CaSO2 greases include boat trailers, motorcycles, both power and hand operated railway switches and any where else where water can be present.
Where a manufacturer has several grades of grease in one product line, you may notice that a lighter grade, such as a #1 instead of a #2 may have a higher base oil viscosity and less thickener. Or visa versa.
In these cases, go with the recommended temperature range the grease is suitable for in the PDS.
In my above recommendation for bicycle gear clusters, a high base oil viscosity with less thickener in a #1 or zero grade may be more appropriate than a #2 with a lower base oil viscosity that would work in automotive wheel bearings in a cold climate.
