i have a '46 willys that has a 50s model 3b f-head engine.. i have no idea ho wmany miles are on it but all i do know is that MMO has worked wonders for me... on this project 2a of mine...
the jeep had water in the oil when i bought it and got it running with using MMO and about 4 or five oil changes with nondetergent oil...
as for my question .. or to get to the question .. last november.. i pulled the oil pan off and cleaned the darn thig with diesel and cleaner of some sort.. not really sure.. and also cleaned the grud off the oil pick-up... Since i cleaned the oil pan off really well and put it back on and changed the oil to DELO straight 30 weight... my oil pressure cold is close to 50psi..and with this older engine and ITS suppose to it drops to below 10psi.. YEAH yeah i know that is low but if u have done the research and asked fellow willys owners like i have this is normal....
NOW for the question ... i have had the SAE 30 DELO in it for 7mths and the last time i was over where the willys is the oil dipstick still showed sign of some water getting into it.. white spots in the oil... hence possibly now being a cracked head.. which i think its just condensation buildup...
BUT here's finally the question .. i am thinking of adding a bottle of the MMO and driving it all day around that farm and such ..then an oil change... and seeing if the MMO will do anything ... in helping with this lil problem since i dont have the money now to do a engine rebuild..??? so really this was just asking for an opinion more less than a ? i guess....
