Originally Posted By: built
good advice,thanks.
been wanting an excuse to go purple,lol.
now to find the racing purple and not just regular purple.
or is the regular very good too.
Ok, 1st off let me state I was not trying to steer you towards Royal Purple or any other brand specifically. I use RP and like it but I don't try and force that on others. Redline would be another very good oil for your application. Redline also has an additive for their oils that increase ZDDP. I personally would run RP or RL in your application but I am sure there are others oils that would be good too. Brad Penn does a really good high ZDDP oil as well but they don't offer any synthetics. Just high performance conventional oils. They claim they are for high performance street/strip cars though so it may fit your bill.
I really don't know enough about your engine, other than it is souped up some( how much? ), and just how much abuse you will put it through to say a regular SL oil will do or if you should jump up to a Racing oil? Seeing as you say it will be driven on the street often I tend to think the regular oil will do but maybe with your mod's the racing oil would be better?
My advice is to do what I do when I am unsure which to go with. That is to contact the tech departments at the oil mfg's you are interested in and let them know about your engine and mod's plus how you will use it and they will recommend the right oil for you. At RP ask for David Canitz who is head of Tech Support. Great guy who won't steer you wrong.
RP's regular oil is excellent. I run it in my DD's and I have run it in muscle cars and mildly modded hot rods and drag cars. I have friends who have done the same and it has done great. One friend even ran the regular RP in a really hopped up Olds 455( 11 second drag car )with no problems. Their racing oil is excellent as well. There is a guy on here with a souped up HEMI that had bad luck with it but in my experience it is excellent.
Again, contact RP and RL, or even Brad Penn, and ask which oil is right for you. Also, when available you can use the dealer locator function to find local sources for the oils..
Royal Purple:
Home Page - http://www.royalpurple.com
Tech Support - [email protected] ( put attaention David Canitz in subject field )
Dealer Locator - http://royalpurple.findlocation.com
Redline:
Home Page - http://www.redlineoil.com/default.asp
Tech Support - http://www.redlineoil.com/tech_requests.asp
Dealer Locator - http://www.redlineoil.com/dealers.asp
Brad Penn:
Home Page - http://www.bradpennracing.com/
Tech Support - http://www.bradpennracing.com/contact.asp
Dealer Locator - None shown
Hope this helps you out. Good luck.
good advice,thanks.
Royal Purple:
Redline:
Brad Penn:
