Thanks to everyone who has replied,
Originally Posted By: Doog
You can probably run a 30w or 10w30 in there.
Doog, Sae 30 has been what I have been inclined to use especially in the motor and maybe the 20 in the transmission.
What's the thermostat temp, if there even is one? A lot of older water cooled marine engines run about 125-130'F. That would go well with a 20 weight.
eljefino, it is interesting that you should mention that. I never considered that originally these engines were all raw water cooled with about 160 degree thermostats. Later on they were changed to a closed system with antifreeze that is cooled with raw water. This is what I have, and the thermostat is rated to be fully open at 190 degrees. However, the raw water is first pumped through the transmission then onto the closed system for the engine cooling. So, I have no idea what temps the transmission runs. I assume it would be lower than the engine though. Oh yeah, I forgot they did change the spec for the engine near the end of production to 20W30 for above 50 degrees but they did not change the spec on the transmission.
GreeCguy, the specs for your tractor would seem to make more sense to me, and that is why I am questioning the 20 wt spec Volvo used for this engine in higher temps. They only specified above and below 50 degrees. I don't know what the high summer temps are in Sweden, but I'm sure it is lower than South FL. I just wonder if they took that into account. I think since they changed the spec on the engine to a 20W30 at the end of production, a 30 would be fine in the engine particularly when I consider what eljefino brought up about the lower temp of a raw water cooled engine. But the transmission is what really bothers me, and it doesn't look like they change the 20 weight recommendation on it. I have already had to have it repaired once because of a worm out clutch, and I don't want to do it again.
Donald, why non detergent for the transmission? The transmission is a splash type lubrication system and uses ball bearings. Is that reason or am I just completely off base.
Thanks again.
