My grandad gave me an old Homelite blower that has not been run in years. I changed the plug, put in fresh fuel. And sprayed out the carb with carb cleaner. It ran great the first time I used it but started acting up the next time. I had a hard time getting it to run on no choke. This unit does not have variable speed. Has the old levers to go to no choke and to shut it off. I tried using it today and for the life of me could not keep it running unless the choke was between half and full choke. Even with that the rpm fluctuated so much it was pretty much useless. I sprayed carb cleaner in the choke while running to see if I could get any other crud out and it would run great for a few seconds.
What do you all think? Do you think some crud was dislodged in the card causing this?
Thanks!
Thanks!
