I have not used or started my old single stage honda snowblower in a few years. I was tunning up my lawn mowers and decided to do the same to the snowblower since all the tools were out. Cleaned out the fuel tank (it was dry as well as the carb float bowl)with Gumout Carb cleaner. Everything was pretty clean. Main jet was not clogged, ran wire through it and sprayed carb cleaner through it.
Started mower with choke, fired right up, turned off choke, let it run for 8 minutes and then it suddenly died with no warning...no sputter...just dead. There was some residual Gumout carb cleaner in the fuel tank when i cleaned it and I added a few quarts of fresh gasoline to that. During that 8 min run time, it was never smooth, it doesn't surge but it's close to that without wide ossilation of revs. My memory tells me this is somewhat normal for this machine since I have owned it. Runs pretty smooth, then some roughness then quick recovery and smooth and roughness....continous cycle. I wanted to see if I let it run for a long time if it would slmooth out. See pic of spark plug, looks bad, what is the diagnosis based on the pic and symptoms described. Also, would not restart when I put the plug back in after wiping it off. Any help is appreciated. Thanks Tim
