Originally Posted By: apwillard1986
The seal conditioning additive is generally ester oil. Some new car manufactures use oils that are high in esters and they aren’t dropping seals.
I wouldn't use any HM oil unless the engine was leaking and too expensive to repair the leak.
Messing around with seal swellers is bad business IMO. Some seals work well with esters some turn to jello and others just leak even more.
The problem is inside the engine there may be many different types of materials in use for different seals.
Unless you know for a fact that every seal is compatible with the sweller component i wouldn't let it near my engine.
A swollen seal may seal short term but may return and leak even worse later.
This is the reason synthetics oil got a bad rap for causing leaks years ago.
They were true synthetics not this HC GrpIII dino stuff posing as synthetic and were PAO or ester based or a blend of both.
Many seals of this era were Nitrile based and not compatible. Most seals in modern engines have no problems but some Nitrile seals are still found.
When i did the cam seals on a Subaru i looked at Fel-Pro seals and found out they are Nitrile. OEM was a different material.
If i had used the Fel-Pro ones and a true synthetic oil chances are it would leak in a short time.
From SKF.
http://www.skf.com/binary/12-64763/TT08_036.pdf
http://www.vurup.sk/sites/vurup.sk/archi...09_sagi_017.pdf
This is just info i picked up over the years, i am no seal engineer but the info appears accurate. Take it for what its worth.
The fact someone else used it in one engine and had no issues is IMO meaningless unless their engine has the same seals are yours.
