Originally Posted By: Shannow
Theory eh ?
Exactly.
I stay out of your endless back and forth threads with Caterham for good reason; it's two opposing viewpoints with no 100% correct answer. No different really than two people arguing about whether or not God exists.
While others may gobble it up, posting tables, and then supplying your own interpretation and subsequent conclusions isn't impressive. But hey, it is novel to see you trotting out the Sommerfield (1904) solution, of which pressures are rarely encountered in real bearings.
What we DO know is that the OP has lower then recommended oil pressure (for a stock engine, stock clearances, with OEM recommended grades)... from this, we can deduce that the clearances are opened up some.
In the rush to demonstrate what you believe, we do know that you got this one fundamental fact completely wrong. His oil pressure well exceeds the recommended level per the FSM data I provided.
Theory eh ?
Exactly.
