Captain_Klink - I reference top mechanics and automotive machinists, because they get to see, and have to deal with, the real world results of what engineers decided were their latest and brightest ideas once.
Oil isn't the best line of defense, its the only line of defense. The thinner you make that barrier, the easier real-life variables can break through.
Yes, it needs to be thin enough to get everywhere its supposed to, but in my experience, not one bit thinner.
Also, as a side note - By contrast to the usual oil change rules, there is a fellow in the area who operates his vehicles like he did the aircraft engines he was responsible for in military service: Never, ever, change the oil, just change the filter religiously every 2000 miles, and top up the crankcase as needed. With several hundred thousand miles, it ran perfectly quiet and was as strong as ever. Go figure.
mechanicx - You're right, by the numbers 5w30 isn't far removed from 10w30, but more importantly, back when 10w30 was spec, nobody I knew, or heard of, used it for anything except for:
1. New vehicles, maybe the first 10-15,000 miles
2. Winter weight oil in the coldest weather
3. People who didn't know any better
4. People who insisted on saving $0.10 per quart on oil
Engines always ran better, were much quieter, and lasted alot longer with 10W-40 at least, or whatever suited the miles and wear. Whatever, it doesn't matter now.
Yes, it is a puzzle to me as well, its sensitivity to oil weight vs temperature, and the pattern of its noise.
For the most part, what I am hearing is piston noise. I think when the oil weight vs temperature is right, the cylinder walls get maximum flooding from what its able to pump. This is enough to eliminate noise from what must be pistons that are now on the loose side, having removed the deposits on them (best guess) by switching to synthetic.
Why it has trouble pumping even factory weight oil when it gets near freezing, I don't know, and I literally can't afford to find out. I broke my own rule about buying a car I can't afford to tear down.
The other noise I mentioned, a low frequency idle noise (only when using the heaviest weight oils or hitting lowest temps) makes me think of mains that aren't being supplied properly. That brings it back to having trouble pumping oil that's even a little too stiff (for its current internal condition).
The vehicle does so well when the temperatures are above 50 degrees, it doesn't seem like the same vehicle. Its quiet, and everything is happy. Must be the oil moves well enough, and the pistons are hotter, getting tighter and staying straighter in their bores.
Going down the temperature and oil weight scales, I think I'm just maintaining the (extremely narrow) viscosity window its happy with.
Short of internal mechanical issues I can't afford to fix, the shedding of internal deposits could have partially blocked or jammed (which has been suggested) something in the oiling system.
That was why I tried Seafoam. Auto RX has been mentioned as a cleaner, and you mention MMO. Being new to the forum, I'm not up on all the abbreviations. What does MMO stand for?(sorry to have to ask).
Also, I was putting cleaners last, since the oil seems to stay quite clean visually now. Would they remove dino oil deposits that all these synthetic changes would have missed?
Thanks all, for the input on this.
