Originally Posted By: DragRace
Originally Posted By: Mach1Owner
Originally Posted By: Bundy78
Thanks again for all of the information. From what I gather, it sounds like Mobil 1 is fine. I was considering changing to Red Line or Royal Purple, but I may stick with Mobil 1 and think about changing weight.
I did have the car tuned by a very reputable tuner, so I'm positive that air/fuel ratio is in good shape.
Don't bother with RP on a 4v mod motor. I have seen some engine builders say that out of the ones that have had the oil pump fail, most were using Royal Purple. If Mobil 1 is working just fine, why risk it even if its not true?
I've heard alot of misinformation on these forums,but this is tops right here! Oil pump failure because of using royal purple oil? Really and you believed it? Seriously,I know at least three people who use royal purple in their mod motors with no issues.I want some more information on this because,I've built motors myself and quite frankly do not believe any of this.
Me neither.
In fact the forum has pics of cams from a mod motor where the owner used RP and the cams look brand new at the high mile removal time.
I've got 2v engines,4v engines,nitrous fed and my current 4v is going to get the ported m112 I've got sitting in my garage at some point and I've run various oils in various grades.
In fact it's my old 2v that brought me to this forum.
Royal purple is a great oil I'm just not prepared to pay that kind of money for it. The stuff with synerlec is a cut above most oils on the market and I truly believe that stuff makes it one of the best available on the market.
So the tripe mr Mach 1 up there is saying is truly laughable.
Oh. And I've never had an oil pump problem,ever. Nor have I ever seen one.
I'm a part a 2 local mustang clubs and likely 15 forums,and I can truly say I've never,ever read or seen any oil pump issues either.
I've been collecting,driving,and blowing up mustangs for years and not a single one blew due to an oil pump or oil issue.
Nitrous however I've blown intakes,and hoods right off before,but that's another story
