$69 seems about right for a synthetic oil change....here in my neck of the woods, my local Walmart does a Full Synthetic Lube Oil and Filter change + top of all fluids and vacuum carpets and wash windshield for $55 though.....I'd definitely shop around.
As far as your car ONLY taking synthetic......I don't know about that.....I know a lot of the newer cars ARE coming off the assembly line with initial fills of "synthetic" of some sort.....but I'd definitely check your owners manual to see if "Synthetic" is REQUIRED under warranty.....
Actually, take-back. If your OIL FILLER CAP states 0w30 - that would mean "synthetic only" since the zero weight oils ARE synthetic only....heh.
But yea, definitely shop around. Some shops will even let you carry in your own oil and/or filter....to the point where you only have to pay the labor rate (generally $12-$20 or so, depending on the shop.....)
The nice thing about Walmart, is you can get a 5 quart full synthetic Royal Purple 5w30 oil change for $55
After this rinse phase with MMO, I think I'm gonna give it a try....put a "tiger" in my tank :rarrrr!!: lol.
