You don't need loose clearances to use a higher grade. Clearances here dictate a minimum HT/HS, not a maximum.Clearances aren't necessarily loose enough that I'd consider a 50w. May perform better with 40w or even 30w. Run what the builder recommends through at least break in and pay attention to oil pressure. 50w could keep it pegged on the relief spring when cold, and more pressure than needed when hot. You're in a hot region so maybe 50w is warranted. The pressure gauge will give an indication of weight. I can't recommend any particular oil over another, not knowledgeable enough for that.
