The MSDS for the 10w40 has this listed at 13.9 CST.Quaker State All Mileage 10w40 has a CST of 15.7 @100°c. That with a bottle of Schaeffer Moly EP will take it up to a 60ish grade. May try this combo, ran it for a long time in my C1500 until I had the pump changed. Did see they make a 20w50 which by itself may do the trick.
Here is where I got it.The MSDS for the 10w40 has this listed at 13.9 CST.
Gear lube is about the equivalent to a 50wt oil.If it starts making noise you could even try some 75w-140 gear lube, just as a experiment
I've always wondered if gear lube works as engine oil
https://blog.amsoil.com/gear-oil-vs-engine-oil/If it starts making noise you could even try some 75w-140 gear lube, just as a experiment
Current ATF doesn't have much in the way of detergents. It doesn't see combustion contaminants like an engine does. Don't know how this myth got started other than in the 50s and 60s Dexron had a lot of sperm whale oil which was an ester.Good cleaning oil or a quart of transmission fluid to clean the engine up for a few hundred miles
That is the PDS. The Manufacturer Safety Data Sheet has it at 13.9 Go to Google and put this in exactly as shown. gsap_msds_02147811. This will give you the msds link to Shell.Here is where I got it. View attachment 165717
That SDS was published in 2020, so who knows if it'd be the current one, I tried the shell product cataloge but they don't have an SDS listed for the 10W-40 viscosity.That is the PDS. The Manufacturer Safety Data Sheet has it at 13.9 Go to Google and put this in exactly as shown. gsap_msds_02147811. This will give you the msds link to Shell.
You do know that gear oil and motor oils are rated differently? A 90 wt gear oil is a 40 wt motor oilIf it starts making noise you could even try some 75w-140 gear lube, just as a experiment
The MSDS is for the 10w40 Quaker State AM.The PDS stated earlier is from Sept. of 2020. The MSDS is from Oct. 2020.The MSDS is the most recent info regarding the QSAM oil.That SDS was published in 2020, so who knows if it'd be the current one, I tried the shell product cataloge but they don't have an SDS listed for the 10W-40 viscosity.
I didn't know thatYou do know that gear oil and motor oils are rated differently? A 90 wt gear oil is a 40 wt motor oil
