So, I’ve read a lot of threads. People like M1, PP, RL, Amsoil, etc. All good oils.
So, the application is a Mazda DI. Engine recently built. Car is a 2007. Will use break-in oil at first. Stock recommendation is 5w-30 I believe. Not concerned about Mazda warranty, that is long long over.
So, fuel contamination is known for these cars. Though I am adding an air/oil separator to help decrease oil contamination. This engine also known for carbon deposits given that it is DI. However, I am going to be using secondary fueling, with something called a Split-Second controller. So, the secondary fueling is with additional conventional injectors installed into the intake manifold. So that should help mitigate the carbon issue at least to some degree.
So, the car is turbo stock, but I’m getting a bigger turbo, along with the additional fueling and tuned for E85 gas. I’m using a Precision Turbo 6062. I’m told that I should be able to get about 600 WHP. But, I don’t have it yet, car is still being put together. But, thinking about what oil I would use after break-in?
I’m leaning towards with Motul Sport 5w40, or Renewable Lubricants BioSynXtra HD 5w-40. I have read that the RL is noted for being best-in-class handling of fuel dilution. Opinions?
