Oil recommendation for 2011 Infiniti G37x
DE
Just wondering what you guys would recommend for a 2011 Infiniti G37x. It has a 3.7l V6
I have done some research on an Infiniti forum and people seem to be all over the place. Some use conventional some use synthetic. People are using all different brands.
I have found out that the Infiniti stock fill for this car is there 5w30 conventional with 1% ester oil additive. I am leaning towards using this.
I guess I am used to seeing people come to a general consensus on my 3rd gen rx7 forum (Castrol GTX 10w30) and my Subaru WRX forum (Shell Rotella T6 5w-40)
Thanks,
Drew
Originally Posted By: Bandito440
What does your owners manual require for weight and certifications in order to keep the warranty?
+1. Very important.
Use any 5w30 SM/SN. I used Pennzoil Platinum / Pennzoil Ultra, which were shown to hold up well in some people's used oil analysis. The Nissan "Ester" 5w30 did not hold up well, with the viscosity thinning dramatically with use. Some choose to go out of warranty to Mobil 1 0w40.
Infiniti UOA Google of BITOG
Good luck from a former G37S owner.
Manual says Engine oil with API certification Mark *1*3.
Viscosity SAE 5w30
API SM
Energy Conserving
Thanks coprolite for the useful info and link
Car is specced for an API 5w30 conventional
Conventional: Valvoline Premium or NextGen preferably
Synthetic: Mobil 1 0w30 or Pennzoil Platinum 5w30 or Pennzoil Ultra 5w30 preferably
5000 mile OCI on conventional
7500 mile OCI on synthetic.
See my sig. I use Pennzoil Conventional for the severe service 3750 mile OCIs. Stay away from the Genuine Nissan Ester oil unless you have money to burn. Note that Infiniti/Nissan of Canada use Mobil products (conventional, synthetic blend HM, and synthetic) as service fills.
At my friend's Infiniti repair shop, he usually uses Amsoil Signature Series or Mobil 1 Extended Performance with the Amsoil Ea oil filters. I think he advises his clients to run 7500 mi intervals.
Different engine -- 2010 Armada does excellent with 5-30 M1/Pur 1 and 7500 OCI. I'd go with PP, PU, or M1 and a used oil analysis at 7k to see where you are at. Nissan's will tear up an oil.
