Hello all, looking for a recommendation for my 2007 Honda fit.
About the car: 2007 Honda fit with
1.5 liters in-line 4 front engine with 73.0 mm bore, 89.4 mm stroke, 10.4 compression ratio, overhead cam, variable valve timing/camshaft and four valves per cylinder. It sees a lot of short trips (about 5 minutes per trip) each day of the week, and highway 2 hour, once a week. Owners manual recommends 5w-20.
Car has 80 000km (48 000miles) on it now, I have used dyno Castrol GTX 5w-20 oil and Fram filter every 5000km (3000miles) until 75000km(45 000miles), from 75000km(45 000miles) to now, I have used Pennzoil Conventional 5w30.
Also, I live in Ottawa Ontario, so it will experience some very cold days for the next few months. Winter temps usually in the 20's or below.
So what would be a good oil for me? I was leaning towards synthetics because of all the short trips I do, But is the cheapest dyno oil that is available on the shelf good enough if I change it every 5000km (3000miles)?
The Castrol GTX seemed to expensive for nothing, thats why I switched over to Pennzoil conventional, but I accidently bought 5w30 by mistake and putted it in the car, should I continue using 5w30 or go back to 5w-20..
Thanks for the help.
