OVERKILL
$100 Site Donor 2021
Originally Posted By: QuadDriver
They are very forgiving engines, and both of mine make WAY more power than yours does. One of them easily 2x. And with higher mileage.
But with a rather low specific power output, it is still very easy service.
This is a curious reply you gave him, his 94 5.0 F150 made 205hp, 275 T, your 82 capri made 138hp if standard, 157 if the mercury 'gt' and 270T, the town car made 150hp (160 if dual exhaust) and 270T.
and his truck had an axle ratio availability that you cannot get - he most likely has the 3.55 but could have the 373 or 410 (Id have to look on that)
So Im not sure the issue you have with his specific output. (most people dont know this, but unless you got a cobra, the heads used were all E7TEs, the lower intake the same and the cam grind nearly the same.
LOL!
My '82 Capri has an engine from my (RIP) '87 Mustang GT in it. I can't believe you assumed it would be stock? Or that I would be retarded enough to think that something with E7's would make 400HP? Naw, the only reason I mentioned the specs of the Lincoln was because he asked!
Regarding the Capri:
-The heads are GT40's ported by Cobra Racing in Toronto, fitted with 1.94/1.60 valves and are O-ringed for the Felpro "lock-wire" gaskets.
-Camshaft is a custom grind from Jay Allen from Camshaft Innovations out of Michigan.
-Rockers are Crane Cobra 1.7's acting on a set of K-Motion K800 valve springs (500lbs).
-Intake is currently a Weiand X-Celerator fitted with a Holley HP-750. Was originally rocking a TFS-R with 30lb injectors when the car was EFI.
-Ignition was a Crane HI-6, but will be getting an MSD Digital 7 setup before it runs again.
Car is in the midst of a Cobra IRS swap at the moment and Cobra brakes w/hydroboost.
EFI in the Mustang, the engine made 325HP with a TFS "stage 1" cam and no tune.
That was the engine I was speaking of that makes easily 2x what his high miler E7-headed girl makes.
BTW, the Lincoln has 3.27's, but I have a set of 3.73's in the basement for it. Capri will be getting 4.10's. I sold the factory 3.27's out of it to a buddy of mine, who needed them for his '82 Capri, which has a 534RWHP supercharged 302 in it.
There was no "issue" with his specific output. Just letting him know I run the oil I recommend in something that spins higher, and makes way more power than what he'll be running it in. That was all I was hoping to get across.
LOL!
