- Joined
- Nov 5, 2022
- Messages
- 81
About to buy a C10 with a 283 from 1964. It doesn't leak currently and runs well.
it's just a thick high zinc oil with i think 1200ppm zn and that's what's considered "classic' but 15w40 hdeo or Mobil 1 0w-40 all have around 900-1100 ppm of zinc and phosphorous while 15w-50 is 1300ppm and is just better formulated. The price gtx classic isn't too good. A few bucks more gets you 15w-50 and for a lot less any cheap hdeo will still protect it way better than what it used to get filled with back in the day.Is the Castrol GTX Classic good by itself? Would additional additives be beneficial?
It was formulated for classics. I have 6 quarts on the shelf for my 65 Oldsey 4-4-2.Is the Castrol GTX Classic good by itself? Would additional additives be beneficial?
Shell Rotella T 15w40@JeffKeryk what brand of HDEO do you like?
What oil did the previous owner use? Does it still have the ram’s horn exhaust manifolds and a vent/oil tube in front of the engine going through the intake?About to buy a C10 with a 283 from 1964. It doesn't leak currently and runs well.
This.Is it the original 283 in it?
283 don't care what oil. It just wants to be full. It's had 4000 different brands and weights in it's lifetime and made it this far. Probably been rebuilt in a garage 6 times by now using JC Whitney rebuild kits. Keep an eye on consumption, it's going to use more than you think, it is not a modern no/low consumption motor!
Yep, that would be my pick too.Shell Rotella T 15w40
