Manual Transmission Recommendation - 64 Chevy 4 speed
My C10 pickup has 4 on the floor. I don't know if it is the original transmission or not (I think it is). It is attached to a 283 V8.
Can someone help me figure out what transmission fluid would be best for this?
The only 4 speed offered in a '64 C10 would be a Muncie SM420 "Granny Gear", They called for SAE 90 mineral oil gear lubricant.
If the unit has a PTO Cover....It's either a SM420 or a later SM465.
An SAE 50 motor oil would work......Though many run 80W90 GL-4 & GL-5 gear oils in them though I would caution against GL-5 oils.
As @clinebarger stated the 4 in the floor of that era was usually a Muncie design that required a 90'ish grade gear oil.
With much better dedicated MT gear oils today you have a choice of modern MTF's.
Those in the list below in BOLD would be my choice picks in no particular order.
MTFs in the 14-15 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission Fluid XT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-90
9. LIQUIMOLY 75W-90 GL4
10. PENNZOIL 75W90 GL-4
11. MOTUL GEAR 300 GL-4/GL-5 (PRODUCT NUMBER 100118)
The 4 in the floor was usually a Muncie that required a 90'ish grade gear oil.
Those in the list below in BOLD would be my choice picks.
MTLs in the 14-15 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
Thanks for the list! Any idea on the capacity for this transmission?
I am going to try Redline MT-90 GL4.
Sounds like a perfect application for a high quality API GL-4 gear oil.
JD HyGard (or Low Vis HyGard) is an excellent choice and you don't have to pay the premium of Red Line or Amsoil.
Hy-Gard transmission / hydraulic oil
I can personally confirm that HyGard LV works exceptionally well in manual transmissions that utilize brass synchros in my climate (-30C to +30C).
Tomorrow Ford Motorcraft Transmission fluid arrives!
Anything I need to be aware of or is it just drain and fill?
And he might have a Muncie M20/21 or a Borg Warner T10 for all I know, Just no trucks ever came with light duty 4 speeds from the factory except some early 80's 1/2 tons with the optional 4 speed (3 speed w/ Overdrive) which is actually a New Process A-833/NP-440 most notably used by Chrysler.
If there's any brass in there yes stay away from GL-5
`View attachment 127148
Redline makes everything shift like a hot knife and butter
