Still on my quest to find a better fluid than ATF+4 to use in a 6-speed manual transmission (Getrag). I am a bit concerned about the viscosity when the vehicle is used in hot temps, being a turbo application with almost 300 hp. I also have concerns about ATF+4 having the right friction for proper synchro operation that you might find in manual transmission lubes. Amsoil offers a synthetic ATF, and BMW has an ATF type of fluid for their manual transmissions. Does anyone think either of these fluids might be better than ATF+4, or recommend an other fluid type ?. Thanks for any replies.
