Hello, this is my first post, almost a year lurking and learning but never registered until now. The car with the engine is a 1984 Dodge Caravan, the Chrysler Factory Service Manual (FSM) shows in the oil pump section a "4 psi @ idle" to be good, in the engine lubrication specs shows ""40 to 60 psi" to be right, no RPM. For what I have been able to find in the web, Mitsubishi requires 78psi @ 3K RPM for a 1983 engine to be healthy, the engines were the same from that year onwards regarding lubrication and clearances turbos and NA until the end of production. Does any of you have the specs. for a 1984 NA engine? and Which specs. should I follow the one from the engine maker or the ones from the car manufacturer and if the latter at what RPM max pressure?. Many thanks in advance
George.
George.
