I did compare back-to-back the oil pressure recorded through HPTuners between two "Racing Oil Filters" on my based LS6, same oil (RLI HD Low ash 5W40), oil pressure sensor in its OEM spot, same oil temperature (220*F) and same water temperature (185*F), oil filters filled before installing:
- FRAM Racing Hp20:
Idle is 32 PSI
From 3000 rpm to 7400rpm is from 42PSI to 49PSI
- MOROSO Racing 22462:
Idle is 40PSI
From 3000rpm to 7400rpm is from 52PSI to 62PSI
Which one is better than the other in term of oil flow/lubrication and engine safety?
Christian
- FRAM Racing Hp20:
Idle is 32 PSI
Idle is 40PSI
Christian
