This is a follow up to an old thread, I have since done 3 used oil analysis, it showed aluminum and Iron content in the oil was high, everything else was good including viscosity. In the first 2 analysis they though the aluminum was from piston wear, but in the third they mentioned there was no lead present ( in I remember correctly) which there should have been if it had lead bearings so they speculated that it had aluminum Berings and the aluminum could be bearing wear. Iron would be cylinder liners. I haven’t had the problem as I haven’t towed a trailer a long distance. I don’t hear any knocking and the motor uses no oil for local driving and a minor amount on a trip, no trailer. I’m thinking I’ll drive it there’s a problem, and if there is probably a jasper or other reman motor. Jasper has a AFM delete option for new motors. Time will tell.
