Cutting a filter open at home is something to do before paying bucks to drop the pan. If your oil pump pick up is getting clogged witch it could be, you should have some junk in the filter.
I just pulled the pan on my Dad's sludged up engine and the pick up was pretty sludged up, as was the filter. So pulling the pan is not a bad idea unless it's not needed. Worst case scenario you have a brand new oil pan gasket........
