Originally Posted By: m37charlie
I agree with a lot of the above comments. Incredibly, US mfg'd motorhomes have huge gas sucking petrol engines with tiny 5-6L sumps instead of the IMHO better European solution of a 3L modern diesel (still put out over 300 ft-lb) with a 9-10L sump.
The stress on your oil (in terms of MW-hr/L or kw/L or hp-hr/L) must be incredible.
Charlie
Well, if you look at the initial post, we ARE talking about an 80s-vintage motorhome. Most US-manufactured motorhomes these days have a Cummins B-series in them, and yes its better from a power, effiency, and driveability perspective.
But give the old "gas sucking petrol" engines credit- they did the job VERY well back in the day. And big-block engines like the OP's Chevy 454, and the other poster's Dodge 440 are actually very easy on oil, even when worked very hard. Most of the cooling is done by the ample water jackets, and the oil temps aren't astronomical at all. Conversely, you mention a "3L modern diesel," by which I assume you mean something like a Benz CRD in a Sprinter chassis RV. Those are actually kinda notorious for *high* oil temps, aren't they? Certainly higher than a 454 or 440 would ever generate.
People today forget that tandem-axle dump trucks in the 60s and 70s would often have a Dodge industrial 318, Ford industrial 370, IH 345, or a Chevy 350 under the hood, and they'd run for years. Not quickly, but diligently. The bigger ones would get a big-block like a Dodge 413 industrial, or the industrial version of the 454, IH 549, or Ford's industrial 429 among others. Single-axle dumps often had a Chevy 292, Ford 300, GMC 305 v6, or Dodge 225 straight six (industrial versions, of course). No one today would EVER think of putting a small-block sized gasoline v8 or (heaven forbid!) a gasoline six in something that big nowdays, but it used to be the norm.
And speaking of vintage motorhomes, I spotted one on I-10 a couple of weeks back of a type which I hadn't seen in many years- one of the streamlined, tandem rear axle front-drove GMC motorhomes. Humming right along with traffic, not breaking a sweat. IIRC those had an Olds 455 and basically the Toronado front-drive layout. I've always believed (and still do) that the Olds 455 may have been the gasoline v8 best-suited to heavy truck duty of any of the Big 3's engines. Monstrous stroke, more torque than most diesels at low RPM, lots of cooling, HUGE bearings (to the point that they were a liability at high RPM in cars like the 442), and all-around rugged construction. Yet, as far as I know, the only truck-like application it ever saw were those GMC motorhomes. Go figure- but then GMC always did have a tendency to waste some of their best engineering in the wrong applications.
