I keep 5W40 full synthetic in my portable generator - because I bought a jug of Chevron Delo full synthetic on close out -I use to use 5W30 full synthetic.
If I need it in the winter I am good to go - and if I still need it the next day I would use 5W30 or 5W40 depending on my mood.
But if after a hurricane and it is 102 degrees outside I would start off with the 5W40 full synthetic because I want to get the power back on - but as soon as I had the chance I would swap it out for 15W40.
I understand changing the oil in a stand by unit is harder than changing the oil in a portable -
my portable unit cost $900 - if I spent $14K on a standby unit I would not be trying to save $15 on oil - I would use quality oil appropriate for the outside temp and change it often.
I may even look into one of those oil vacuum things that suck the oil out of the dipstick on cars -
If the standby unit called for oil change every 200 hours I could see myself sucking the oil out every 50 hours and changing the filter at 150. This is what I did with my motorcycle. To try a scrimp on oil changes when you have an expensive "mission critical" unit - it seems crazy to not over maintain it.
