I had previously been running Mobil 1 0w40 in my 2000 Z28 Camaro LS1 with about 45,000 miles on the engine. It's a daily driver, mostly in town driving and I don't run it very hard. A few of the oil analysis' came back less that spectacular so I switched to PP 5w30. I've noticed while running the PP 5w30 my oil pressure has dropped a bit and it burns about 1-1.5 quarts of oil between changes. I've not yet had a chance to run an analysis of the PP in this engine.
I'm due for an oil change now and with winter coming up, wanted to get some opinions on what I should run. The Mobil 1 0w40 did not burn anything between changes and is better suited for the cold weather (gets to around -20 or so on bad days) however the PP may yield better wear results. The only things that concern me about the PP would be that it's burning oil between changes and number wise, it's not as good in cold weather as Mobil 1 is.
Thoughts from those who know a LOT more about the subject than I do?
