Have you found an oil that works better in engines that burn oil?
06 Impala 3.5L 50K miles. PCV is not replaceable and has been cleaned. No external oil leaks.
It does not use alot of oil, but its wifes work car, she travels alot, and does not/wont/cannot be trusted to check oil level on regular basis.
Current oil is Farm and Fleet 5w30 (made by Citgo) has the dexos cert. No clue what oil was previously used, but it burned at the same rate on the OCI that I got the car. Probably a dino, OCI was done at an independant shop before I got the car.
What do ya think? Thanks
