Oil filters on clearance at Lowe's.
Apple Valley, California
Might want to check your store. Ph3975a and ph3980 here .
I do often. They are cheaper than the auto parts stores . Those filters are $10 @ autozone. Walmart is a 45 min drive through stupid traffic 1 way so I rarely go there
^this
Lowes is cheaper than Walmart for some models (e.g., PH10575 which is $6.xx at Walmart but $4.xx at Lowes). Most others are about $.25 more at lowes. If I'm at lowes and need a filter I grab one, but both stores are less than a mile from my house so I don't need to make a special trip.
My Home Depot only carries the PH line of Fram which has to low of efficiency for me to even consider. But its efficiency is higher than a lot of more expensive filters.
I like to know who buying an automotive oil filter from Lowe’s or Home Depot.
Contractors and construction crews treat everything bought there as a business expense. An auditor isn't going to check if an oil filter bought there even fits work equipment, let alone verify that is what the oil and filter were used for.
