well. normally i would replace both. I could not get the oil filter off with a crescent wrench around the plastic hex on the filter housing in my 2008 VW Passat FSI Turbo. I was under the car and had already removed the old oil, when i was unable to remove the filter cap to replace the filter inside. Thus i just added new oil so my wife can drive the car the next day.
Now this weekend i am buying the 16mm filter cap socket in hopes that this will break the hold on the filter cap from its housing without destroying either. However, i really don't want to drain the new oil a second time. I would just like to open the spicket on the filter cap to drain the oil from the filter and then remove the filter cap with the new socket, replace the filter inside and screw the cap back on and done. Is this possible?
That is it possible to drain the oil from inside the filter cap (using the drain nipple on the cap) without all of the oil in the engine coming out of that filter?
Alternateely, i could just drain the oil a second time in a clean pot and then reuse it since it is the expense stuff, synthetic and only has 100 miles on it since last weeks change out. The oil filter is located below the vehicule, tus my concern whether all the oil in the engine will come out if i don't drain the engin first before screwiong out the old filter?
any ideas on what may help to loosen this kind of filter? thank.s
