Good point on the air filter. Which would you recommend?We don't have a best oil to recommend and there will be different opinions. It is quieter here on the weekends vs the middle of the work week. So the opinions you'd get today might be different than what you'd get on Wednesday.
I would suggest using something with a GTL base for low NOACK such as Pennzoil Platinum. Make sure it has the latest specs API SP GF6.
The Fram Ultra oil filter does an excellent job.
The air filter is more important than the oil filter. But that doesn't mean I recommend a cheap oil filter. I wouldn't use a K&N air filter myself if I seeked out maximum engine life.
I wondered who the BITOG " Best Oil spokesperson wasWe don't have a best oil to recommend ...
I would NOT recommend the AC PF63 E core filters are compromised by short pleats and large plastic centertube.I recently purchased a 2016 Yukon Denali. It has 63,000 miles on the 6.2L engine.
What would you guys recommend as the best motor oil and filter?
TIA
I've got a 2021 Tahoe with the 6.2 (L87 vs your L86). The first oil change was free at the dealership, but now that it's on my dime, I'm going to use Harvest King 5w30 from Rural King (Dexos1 G2) with a Fram Ultra XG10575.
All excellent choices.I have Castrol Edge in my Silverado right now. Next up is Castrol Magnatec or Rotella Gas Truck.
Fram Ultra filter.
After that, Kendall GT-1 Max with Liquitek.All excellent choices.
Curious why the change from Edge down to Magnatec?I have Castrol Edge in my Silverado right now. Next up is Castrol Magnatec or Rotella Gas Truck.
Fram Ultra filter.
Well that interesting. Say a curious friend would like to know what was you OCI on the Escort?Any good quality oil will be fine. I had an '88 Ford Escort that was about 23 years old with 518K miles on it when I retired it. I used various brands of conventional 10w40 and cheaper filters in it and the engine outlasted the rest of the car. Even with synthetic oils and filters that are now available I'm still using conventional 10w40 and less expensive filters in all my vehicles.
