Oil Filter Question for Titan XD 5.0L Cummins
Howdy folks! Saturday I purchased a 2019 Nissan Titan XD with the 5.0L Cummins V8 diesel. This engine is noted for having catastrophic issues if the oil isn't regularly changed and a high quality product is not used.
(redacted - Mod)
Now onto the oil filter question:
There's very little in the way of quality filters for these engines. One member of the titanXD forums informed me that the larger filters designed for the bigger inline Cummins engines work on these, and he personally uses part # LF9028 Fleetguard filter. He has an email directly from Cummins stating that said filter should not cause issues with this engine. I have experience with Donaldson Blue filters which as far as I know make the best filtering claims out there (10 micron or larger particles). Does anyone know of a better filter than the donaldsons, or know if something like one of those sketchier looking Doc's filters are acceptable? A Bypass filter is not recommended by Cummins on these engines. From the same email, and I quote the rep: "We generally advise against stand-alone bypass filters on the lighter duty engines mostly due to the fact that there’s not much extra capacity for the oil pumps in those engines."
Thanks for having me, and thanks in advance for your time!
Welcome to the site.
VOAs can be found in the specific section. If you cannot locate them there, it's because they don't exist here.
As for the filters, we have a forum for that also. I'm moving your thread to the filter forum.
In the future, please have separate threads for specific questions and post them in the proper forum.
What's their efficiency percentage claim at 10 microns?
Thanks Newton! Apologize for that. Is it appropriate to ask for VOAs over there?
Yep! I found those and looked thoroughly. Didn't see specifically what I was looking for. Curious if it's appropriate to ask? Honestly I'm curious enough about these 10W30 diesel oils that maybe I'll contribute over there myself
You can do a search in the Used "Oil Analysis - Diesel" form and find some 10w30 used oil analysis, like the one below.
