Originally Posted By: Hokiefyd
I disagree that an ADBV is not necessary on this type of application. A good ADBV will still keep the oiling system of the engine primed with oil for the next cold start. Without an ADBV, the oil in the galleries above the filter will flow back down (through the filter) into the oil pan, often creating startup noise.
Regardless of the filter's orientation, it's my experience that a quality ADBV, if that mechanism is not provided by the filter mount as in some GMs, is advantageous.
We've been through this before. It's certainly possible that there are some situations where this oil above the filter situation might be true, but I'm far from convinced.
My Audi's OEM filters, which I use regularly, have no ADBV. The filter is mounted vertically, thread side up. The filter is nowhere near the lowest point in the oil circuit. Not only is the filter full when I take it off (it would have to be full, since gravity still works), there is plenty of oil above the filter that comes streaming out when I take the filter off. Again, there is no ADBV.
That was also my experience in changing oil hundreds of times in small block Chevs. Those engines had a filter in the same orientation, and no ADBV was specified for that application. The Wix filters of the day had no ADBV for that application, and that's all I ever used.
Currently, however, the Wix 51393, which cross references to the Audi's Mann, Mahle, and Bosch filters, does have a silicone ADBV. The German filters do not. The old Wix Chevy small block filter had no ADBV. The current one very well may.
As I mentioned in another thread, while the Motorcraft FL1A has a nitrile ADBV, the obsolete CFL1 (same applications but cheaper, the FL1A was advertised as a longer life filter at the time) had no ADBV. Many of the applications that specified either filter would have benefited from an ADBV.
Originally Posted By: Mike_dup1
Quote from AC Delco...
· Anti-drainback valves that retain oil in the filter to help reduce prime-times and quickly lubricate the engine during start-up
This is the whole point. If the filter is mounted thread side up, the oil isn't going to go anywhere unless someone pokes a hole in it or the car is parked upside down. My old LTD with sideways mounted filter used to tick like mad at startup unless I had a filter with an ADBV, and such filters were a lot less common at the time. Finding a filter without one these days is more of a chore than tracking down one with the ADBV.
