quote=Pete C.]ADVs are not meant to hold a column of oil in the engine. They are there to prevent the rapid back flow of the oil, on the dirty side of the element, from RAPIDLY backwashing the trapped particulates into the oil pan. That's it, no other reason but that.[/quote]
While that may be the reason the ADBV was implemented, an ADBV that doesn't leak, or leaks very slowly, will also hold more oil in the passages in certain engines. Like I said. the ADV is not designed to hold up a column of oil. If it does so much the better. But don't complain if it does not.
Originally Posted By: Pete C.
Any oil released when the filter is removed is mostly because of a liquids desire to seek a common level. Inlet side vs outlet side. When the filter is removed, there is no longer a connection between both sides and, the oil drains out.
A non-leaking ADBV will prevent the connection from outlet to inlet to which you refer, and hold more oil in place. A filter with no ADBV always has that connection and oil above/beyond the filter is free to flow backwards through the filter and into the pan when the pump stops.Like I said. the ADV is not designed to hold up a column of oil. If it does so much the better. But don't complain if it does not.
On some engines the additional oil held in passages by a non-leaking ADBV reduces startup noise since less oil needs to be pumped to fully pressurize and fill the engine's oil system.
Quote:
Some older GM filters do not have ADVs because of their orientation.
If those engines can't hold oil above the oil filter after engine shutoff, an ADBV is not needed to prevent backwashing. Likewise there would be no oil to hold in place in those cases.
Unless the oil filter is at or below the pans oil level.
No mater what your arguements, the ADV is not there to hold back the return flow of oil from the block and heads when the engine is shut off. Plain and simple fact!
