Originally Posted By: 3311
I'm glad you realize that the oil pump bypass and filter bypass(approx 12 psi as well) are different.
LOL ... I've said that all along. Again, how can I see 75 psi of oil pressure if the pressure relief valve is open all the way at 62 psi as you claim?
Cold oil, high rpms, pump outputting more than can be bypassed etc... The gearator pump does not by pass back to the pan, it bypasses within the pump which may be a reason.
It has been in the 40's here in Fl the last two mornings and both days I was well over 60 psi hile pulling into traffic with my 04 below.
Artic temps down here, brrrrrrr. Thank goodness we are warming up today.
I see oil pressure on the gauge of 70~75 psi when near red line with hot oil (200+ F) - Mobil 1 full synthetic 5w30. Stock LS6.
