Just a hunch, but I bet the hole design/shape/flow characteristics was given zero thought. The engineers designed a machine to efficiently make holes in a sheet of metal, rolled across a plate/conveyor. Instead of punching a clean hole, it's probably a toothed wheel rolled over the metal sheet so they can manufacture these quickly, and leaves zero waste behind (versus a punched hole). Everyone's getting a little overboard with how these are bad, flow data, etc., but until there is data of any filter with this design causing a failure (or at the very least increased UOA levels) everything is hearsay.
