L14476
Type of Filter: Spin-on
Thread Pitch: UNF-2B
Relief Valve P.S.I.: 14-18
O.D.: 2.69
Threads: 3/4-16
Height: 2.93
Anti-Drain Back Valve: Yes
L14477
O.D.: 2.69
Threads: 3/4-16
Height: 3.52
Purolator interchange guide
In WIX
Part Number: 51394
UPC Number: 765809513945
Principal Application: GM (85-08), Daihatsu (88-92), Infiniti (91-96), Kawasaki Mules, Nissan (91-95), Toyota (80-08), Scion (04-08), Atlas-Copco, Briggs&Stratton, Cub Cadet, Generac, John Deere, Kubota, New Holland
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.977
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 400
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Part Number: 51396
UPC Number: 765809513969
Principal Application: GM Vehicles (99-05), Geo (89-92), Toyota (88-08), Various Ford-New Holland Tractors, Suzuki (96-08), Suzuki Marine Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Thread Size: 3/4-16
Gasket Diameters
