In the November, 1972 Issue of Popular Science, there is a large add for Shell's new 'Super X 10W-50' multi-viscosity oil. In the add, it states the folowing: (quoted verbatim)
"Hot cranking performance is a good test of an oil's ability to hang in there"
"Ever stopped an engine after a hot run, then noticed how slowly it cranked when you fired up a few minutes later?"
"While the engine was sitting there cooking, oil between pistons and cylinder walls thinned so much that rings dragged against the walls with high friction, and overloaded the starter"
In my 2002 Chevrolet Cavalier 2.2 OHV engine, I have this problem all the time. After driving for moer than 30-45 minutes or so, when the engine is good and hot, if I try to start it within 10 minutes of shutting down, it will do this. The engine will start to crank, and then will suddenly 'seize' for a couple of seconds, and stop cranking with a very strained sound.
I usually stop cranking the engine, give it a couple of seconds, and try again. It will start, but it still cranks slowly, and a couple of times I've had to use the gas and rev it a bit to get it going. I thought what I was getting was fuel 'vapour lock' from hot fuel in the FI system, but vapour lock shouldn't affect the actual engine cranking speed. It never does this when the engine is cold, or if it has definetly been sitting for more than 20 minutes.
Another reason I think it could be this is that my 2.2 OHV engine is defintly an 'old school' engine design that has more in common with a mid-1970's Chev 350 than a more modern engine. It has bad piston slap when cold, and even some when warm, so its not out of the question that the pistons would 'wedge' in the cylinders, and not move b/c of too-thin oil. I use standard 5w30 conventional in the engine, and it doesn't matter how 'old' the oil is for this to happen.
I'd like to make it clear that I know that an early-1970's conventional 10w50 oil is miles away from modern PCMO's, so I'm not saying I should run out and find 10W-40 or 20W-50 for my car, especially with winter coming up. But it would be interesting to see if running a thicker oil will stop this, something like a HM 30-weight, GC 0W-30, or even Mobil 1 0W-40.
Thoughts?
Thoughts?
