Hi,
as an example; (all temps +/-2C)
Porsche all alloy 5ltr 32v V8 - 320hp (coolant cooled)
Front engined, torque tube to rear transaxle
Coolant
Radiator is heat sink - coolant thermostat operates on bottom hose. Thermostat cracks at 83C and is fully open at 98C (Initial engine warning at 118C, final warning at 120C)
Oil cooler - heat exchanger type in coolest part of radiator. Oil thermostat opens at 87C and is fully open at 91C)
Air flow (flaps) - these are temperature regulated via a variety of inputs. Main input (others are A/c, engine heat, ATF temp)is sensed at coolest part of radiator. This activates flaps to 30% open at 79C. They are sensed and progressively opened at "break" levels up to fully open at 85C via main input. Under body ducted shields are used
Fans (2)- variable speed fans are used. these activate initially at 79C and are at maximum speed above 95C
Note: all systems operate in reverse (from the input matrix) as temperatures decrease
Over many years of testing the maximum recorded temperatures are;
oil = 90C into oil cooler
coolant = 92C
Coolant average = 86C
Core engine temp average is = 89C (vee)
Mostly my air flaps are closed and fans off or at 30% open when the ambient is above about 33C
They are rarely fully open on the open road even at temps around 38-40C and at speeds up to 200km/h+
In very cold conditions the flaps are closed and fans off of course and the engine maintains a "next to zero" air flow regime. In fact I believe in some condition they struggle to get to FI sensor and other actuator sensor temps and this is why the engine has this sophistication
This indicates a very stable cooling system as I live in the Tropics and operate the car in temperatures ranging from -5C to 40C+.
Most of my driving is fast and open road
I believe that this engine has almost perfect temperature regulation
Regards
Doug
Coolant
coolant = 92C
Regards
Doug
