I have a question about oil consumption. Brother's car, 90 Civic 4 door sedan, 337k miles. Started with Mobil 1 5w30 but as the miles piled on he went up in viscosity as the oil consumption increased, finally to Mobil 1 15w-50. Valve seals have been replaced twice, head has never been off, compression is factory spec, car passes Calif smog every time with no adjustments needed, car is maintained by an independent Honda shop with a good rep in the area. When the oil consumption hit a quart to a quart and a half every fill up (300 or so miles) he bought a case of Shell Clean Engine Formula 20w-50 conventional oil (Kragen 2.00/qt) and the oil consumption, after an oil change and a couple of hundred miles, has gone down to about 1 to 1 and a quarter quarts per 1k miles. He is into the second oil change with Shell. The oil is changed every 5k miles. He started with Honda filters but over the years changed to NAPA Gold. The car has no oil leaks, is well maintained, has never smoked, runs well and lives in Southern California where we don't have weather. Any ideas about what is happening.
