TRY THIS: got off honda-tech.com
1. On a cool engine at 8pm I removed the plugs
2. With funnel, added about 1/2 cup of MMO to each cylinder(remove spark plug)
3. Let sit overnight
4. In the morning, took flashlight to make sure no fluid was remaining in the cyliders. (during the second soak, cylinder 4 had fluid still in it which I sucked out with a small tube attached to the tip of a turkey baster). Unplugged distributor base plug and turned engine over just to be sure nothing remained in the cylinder.
5. Reinstalled plugs (dont forget antiseize) in same places they came from.
6. Fired it up and it lightly smoked for only a few minutes. Took it on the highway.
7. Only after the second soak did I change the oil.
Repeat maybe 2-3 or three times. MMO is like 2-3 bucks!
