Originally Posted By: Gokhan
440Magnum, I don't have plug tubes. Plugs are located on the outside. There was never any oil leak from the valve-cover gasket and the outsides of the plugs were always completely dry. This was also no one-time observation. So, your speculation is wrong.
I would believe that... if there were an alternative explanation. Overkill's postulate that enough oil drizzles down the valve, across the top of the combustion chamber, and to the spark plug *might* explain it, but I really don't think much liquid would wick up through the threads of a fully seated spark plug. If I were a mythbuster, I'd give it no more than 'plausible' but it woudl require such a huge leak that I think the plug tips themselves would be gakked up too. And there'd be a huge blue puff on startup.
Regardless, the OP's engine is different, and his wet plugs clearly DO come from oil accumulating inside the spark plug tubes.
