Oil Cold Temp Performance Degrades With Use?
WOW!!!!
This is the best thread posted on BITOG in several years.
I guess the issue applies to diesel only?
You might want to consider to move it to diesel oil forum.
Applies to diesel and gas. The Infineum powerpoint presentation shows data from a pair of VW GTIs with the 1.8L turbo gas motor.
I thought one of the first links detected the issue in diesel using bio fuel IIRC?
Then this is a much bigger issue for anyone in cold climate.
How do you determine what VII additives are used in various oils?
One might consider testing used oil in freezer.
