Originally Posted By: rg200amp
Originally Posted By: randomhero439
To be perfectly honest. For track days i would use a conventional 20w-50 and a Purolator Classic. Change oil when you get to the track, and change it again before you leave. I dont think your WRX has a factory oil cooler like the STI does... am i correct?
This is what i do with my Accord, except i used 10w-40 (Car is specced for 5w-20)
I am a firm believer in choosing an oil grade based on driving conditions.
I appreciate the comment. But I am not putting anything in the engine except 5w30.
I would re-consider your stance here. randomhero439 brings a very good point about track days and the need for something thicker. Unless you install a pressure gauge and/or oil temp gauge, you have no way of knowing that 5w30 is up to the task of protecting that engine, so thicker oil, just for the track event is a safe choice.
Your argument about the warranty is also weak because I'm pretty sure that any track use will void the warranty much quicker than using thicker grade oil.
Subaru calls for 5w30. You know? Subaru. The people in Japan that designed and built the engine.
Subaru of America calls for 5w30. They did not design and build the engine.
SoA got approval from Fuji Heavy Industries to allow 5w30.
05LGTLtd - Other than mentioning that 5W-40 conventional may be used for replenishment, SoA dropped the recommendation of thicker viscosities during model year 2011.
-Dennis
