This thread has no point other than to say that I did an oil change and transmission drain and fill on the Accord in my sig today. Oil and filter that went out was TGMO SN 0w20 and a Honda Genuine A02, this oil/filter combo had 5 months / 3000 miles on it (it was at about 40% or so on the MM, this is the longest I have ever gone). Oil and filter that went in was TGMO SN 0w20 and a Fram Ultra (that I will leave on for 2 OCI's providing the filter does not cause start up tick like the previous Ultra that I used did. This was also the FIRST transmission drain and fill that I performed. All others were done at the dealer. It felt pretty good knowing that I did it myself and at half the cost of the dealer. I drained out all that would come out, then 3 quarts of Honda Genuine ATF DW-1 went in. New crush washers for both oil and transmission plugs were installed. Engine and transmission run and shift as smooth as ever. Here is a quick video of the start up after the oil change/transmission drain and fill.
View My Video
Sorry the video is cut a little short, my phone ran out of storage right at the end and cut the video off. Just wanted to share! Always exciting when you accomplish a new task.
View My Video
