Oil-burning Volvo T6 SI6
Australia
Hello all, happy new year! (It’s already 2023 here in Australia)
My mum’s daily is a 2011 Volvo S80 T6 which has the 3.0L turbo six. It has 185,000km on the clock (~115,000mi) and we only bought it recently with just under 180,000km on the odo. I’m aware the 2011s are known for oil consumption.
In that time I’ve replaced the oil and oil filter twice. The first time with Castrol Magnatec Stop-Start A5 5w30 and a MANN filter. This oil made the car run nicely but it consumed around 1L per 1,000km/620mi. I never let it run low so not a huge problem, but not an ideal rate of oil consumption.
So for the next oil change I thought I’d try an ACEA C3 oil, so I used Nulon APEX+ Multi 2/3 5w30 which is a C2/C3 oil and was on sale fairly cheaply, so I didn’t care if it burned through it quickly. This really slowed the oil consumption, down to about 0.5L per 1,000km/620mi and in terms of engine noise and smoothness etc. it was either the same or slightly better than the A5 oil.
So, what should I try next to improve things further? I usually have Castrol Edge Professional A3 0W-40 on hand as I use that in our Mk2 and Mk3 Focus RSs. Would this be worth a shot in the Volvo? Or should I just stick to a (relatively) cheap C3 5w30 and live with some oil consumption?
Thanks for your help and all the best for 2023
Cheers
Definitely work the HTHS ladder. Give the 0w-40 a run, and then the 5w-40 a run.
Probably verify the PCV breather system and make sure all is functioning and nothing clogged up.
The PCV was replaced by the previous owner within the past 12 months, so I’m pretty confident the crank case breather system is up to scratch. Hopefully higher HTHS and slightly higher viscosity etc. helps out
Regardless, do a few tests at home to verify it's working properly.
There's one specific tube which feeds into the oil pan. If it's clogged, you'll have consumption issues.
It doesn't take much time/effort/tools to verify it's operating correctly.
Youtube has many vids on how to check the system is operating as intended.
Did they replace the whole PCV valve cover assembly or just the PCV diaphragm. The turbo cars did not have the pistons rings with oil burning issues I believe.
T
The entire PCV housing was replaced. Interestingly the oil consumption seems to be gradually reducing since I’ve given it a few short OCIs. I wonder if it had sticky rings and I’m cleaning everything out a bit? Dunno
The 5w30 C3 (cheap Aussie-made Gulf Western Euro Energy) I put in it last time slowed the oil consumption a bit, but not entirely.
I just changed the oil and filter again, this time running Petronas Syntium 5000E 5W-40 C3 and the oil consumption has completely stopped, and there is no longer any smoke at all from the engine at full load/full throttle. Before with the other oils it blew a fair bit of greyish smoke at WOT, now nothing. Cool!
First stop for me with a Volvo that’s using oil would be to renew all the PCV components, that’s for sure.
If you go on Shell Lubematch it will give you all the alternative oil specs
I did that on my Jaguar XJL, and also cross reference different manufacturers that use may use the same engine
That’s how I realised I could use 5w40 not just 5w30 in the Jag
