When an engine is designed by the factory and oil choices are chosen and recommended, do the engineers settle on a specific oil(s) due to its grade (weight), its characteristics, or a little of both?
I have a 2004 Toyota Tacoma with the 2.4 L 2RZ-FE motor and my manual calls for a 5W-30 "API grade SL Energy–Conserving or ILSAC multi-grade engine oil." On the theory that the factory recommended the grade they did based on the characteristics of a typical 5W-30 oil in 2004, I was wondering if those characteristics of that typical oil have changed over the last 13 years and if it's possible to, somehow, compare a 2004 5W-30 to a 2017 5W-30?
Thank you for your thoughts and feedback.
Ed
Ed
