Originally Posted By: artificialist
Originally Posted By: DuckRyder
155.00 from Olathe Toyota assuming I have the right model (4cyl not XLE)
There is however a shim kit too that you might need depending if yours are missing or damaged.
SHIM KIT, ANTI SQUEAL (FOR REAR DISC BRAKE)
Stock Code: 0494506080
$ 26.48
When you buy premium pads, anti-squeal shims arrive with the replacement brake pads.
Maybe, and Maybe they will be as good as OEM... Honda pads usually come with new shim kits. Toyota apparently do not.
Guess the whole thing is moot since the OP has it taken care of.
